ironmike4134
History... friends ski, a shop rebuilt the carb. Had hard time starting (shop said compression issue), but once you got it running it would not idle (without feathering), but it would run to about 47mph and also shoot out of the hole. I got the ski, checked compression and found it low (pulled heads/cylindar). Redid the top end with a kit and had the cylinders machined. While in there I replaced all the old gray fuel lines... took to the lake, starts like a charm, idles now, but the engine seems to "surge" when holding the throttle at a set spot... but the big problem is that if you run at WOT, it bogs down (almost dies) (pulling choke kills it immediately). If you stay at 2/3rds throttle it runs all day at 30... anything over and it bogs. It also does not shoot out of the hole like it used to with low compression.
Checked compression (good in both cylinders now)
Replaced needle and seat in carb (was not done on the rebuild) <-- helped with idle but did not help with bogging problem.
blew air through gas selector, there does not appear to be obstructions.
carb adjusted to all standard settings.
I pulled the carb and checked the rotarty valve clearance (right at limit .035). Timing looked about right (did not actually check with a guage), but no backfire/other issues.
when I pull the plugs, they are black, so think I am running rich (why I replaced the needle and seat).
put a multimeter on the battery to check to see if I might have a regulator problem (no change between engine off and engine running).
I set the oil pump at the proper check mark (but found the cable came off during the ride at some point... could this be my problem? was thinking no as it should just be over pumping oil at low speeds).
The temp guage on top of the head broke off, so it is no longer connected, is there any electronic control to limit the motor if there is no temp sensor?
Only thing I can think of now is that maybe something from the old fuel lines got into the carb (between pulling off the top-end and going to the lake?). I think the next step is to rebuild the carb again? Or could it be something I did when rebuilding the top-end? or replacing the fuel lines?
