Hello all! I started working on one of my project skis its a 1998 GTX Limited. Was told it ran fine but that turned out to be the other jet ski in the deal. When I took it out it would rev to about 3,000 then die out and have trouble starting again luckily wasn't too far from the dock. I was getting the 12v low on the dash. So came back home and started diagnosing the Stator first. When I tested I was getting 0.5 ohms on all three connectors and no connectivity with ground. I can always go and double check that to make sure im doing it correctly. The battery was drained all the way to 5v and wouldn't recharged so I had to go get a new one. Well I ordered a used MPEM off eBay that was said to run fine with no issues. I plugged it in and go no beep or anything with the key with it. The dash would also come back on after pulling the key. Should I just try rigging one of the external rectifiers up? Or any other tests I can do? Any Suggestions?
