I have a 1998 GTS. I was stolen and vandalized :ack:. They tried to strart it and, after failing to do that, pulled the wiring out. I bought a Clymer manual and traced all the wiring out and connected everything back up.
The problem that I have now is I'm not getting any spark. Can someone very familiar with the GTS model describe the spark process?
I know the current is generated from the magnito.
What I'm curious about is how/where the spark is triggered?
Is there a hall effect type device in the magnito circuit?
What role does the MPEM play in the ignition circuit? It appears to me from the wiring diagram, to be a simple on/off security circuit that grounds the magnito (black/red stripe wire) when the lanyard is pulled. Therefore, if that part of the MPEM is bypassed, I should be able to get a good spark which would point to a problem with the magnito. Your thoughts?
Thanks for you help! (trying to get on the lake this weekend!!)
Doug
Doug
