Well, I put the grease in before I seen your message and I think I may have put too much. I sanded down the delrin wear ring so the impeller spins freely. When I mounted the pump back on the hull, I losely tightened the 4 nuts and I turned the engine over real quick. Everything sounded fine. I torqued the 4 nuts down to 24 pounds per the shop manual. I then put in the grease to the zerk fitting on the flywheel. Each pump, I could see the drive shaft move a bit forward and the boot would expand a little bit. I think I put in about 4 pumps with a standard automotive grease gun. Now when I tried to turn the engine over, it doesn't sound the same. When I turn the left engine over, which I have not touched yet, it sounds like it's going to start. When I turn the right engine over, it rumbles for just 1 second and then stops. Since I've torqued everything to spec, I'm wondering if I put too much grease in that zerk fitting. Could it be causing too much pressure on the drive shaft? After I tried to turn it over, I looked back by the boot that's between the PTO and the carbon seal and there's a little bit of grease being forced out under the zip tie. I'm not sure what else it could be. Should I cut the zip tie, let some of the grease out and see if that maybe relieves some of the pressure on the drive shaft?
