If you can check the part numbers stamped on your throttle cables, I might be able to use them.
These are the part numbers I need. The first 2 in the set are the older part numbers, the last 2 are the newer part numbers for the same part. I'd be amazed if they are the same part number, but thanks for checking.
204390027 Right hand cable
204390028 Left hand cable
204390065 Left hand cable
204390066 Right hand cable
**EDIT: Looks like your Challenger cables are 204390091 (LH) and 204390032 (RH). Only check the numbers if you really want to - Cause I've been wrong before! LOL!
