purple_people_eater
it sound like just the starter too me.
He's not saying that's your problem. I have two of those skis and they made that same sound when the starter became dissengaged from the flywheel. If that were my ski I'd shut the fuel off and pull the spark plugs and spin the motor over and see how much fuel comes out. Then I'd put a little fuel/oil mix down the spark plug holes, Gap and insert new plugs and go for it. Don't forget to turn the fuel back on.Thank you Purple....
Just hope it is not the RV. I have already put
money I don't have into getting this ski to run
right. Not trying to question your experience
but why do you think it is 100% the starter?.
Is there something I can do to check that it is just the starter?
Again, Thank you so much for your advice.
If I hit the lotto you will get your choice of any jet ski
you want...
Sethsmind you forgot one....dont forget SBT Motor installed in the beginning of all this. This thing has been a nightmare. Im wondering if that pressed in Brass fitting slipped. Remember the last time it was in the timing was way out... Dialed in the timing and ran great. Met you at the beach and changed plugs fired it up......I rode it around hard for about 15 min...then I left and you guys took off on it and had problems again. Im sure it will get figured out.
Yep it has been at our store. I have to look at the tech report again but I think he still had perfect compression. When I met him at the beach and cleared it out (it was loaded up very bad)...and threw some fresh plugs in it, it ran great. As a matter of fact when I took it out, it was way smoother and better running then my GTX ever was. I put it threw a few different situation trying to get it to act up. Idle, Mid Throttle, wide open...wide open from a dead stop....shut it off and re-started perfect several times. I gave it back,and him and his brother got on. I watched them leave, then I got in my car and left...The next day I got a call that its not right again... I think this ski just has a gremlin in it LOL!! After the compression test the next thing we are testing is the timing again...if its way out then he has bigger problems
Update----Out of time again... RV gear issue. Compression 150, 40.
Yeah I hope so.. unfortunatly he only did the SBT top end...Nobody has dont anything with the bottom end.
Just pulled my records. Let me know what you All.
9/2/2011 R&R Top End - Cylinder Exch top end kit - $948.00 (Took one month to get ski back)
9/17/2012 Replaced starter - $280.00 (Had to bring ski back 3 times in 4 days for this one)
9/23/2011 R&R Carbs - Oring outter - w/ New Fuel Lines - $368.00
4/3/2012 Brass rotary gear may be slipping which caused
latest problem. Might need new motor. Cleaned Carbs for rough running.... rotary valve timing reset and
now runs great. $255.00 Starter does not seem to be engaging right... Fly wheel
and Starter replaced in Sept. 2011
Now on 4/16/2012 they told me oil ratio to rich. Switch to 46:1
Everything stated above was right from the work orders.
With every problem I had (yes every one of them) they never
fixed it the first time and I had to drop my ski off over and over and
over.
So I paid $255 for the latest on going problem and the ski is still
not fixed.
Just about a year and and I have been in the water maybe 45
min. tops all together.
I fully understand problems happen, boats , cars etc. but to pay for
a job and have to bring it back every time over and over.... I just want to
enjoy my ski.... is this treatment normal???
Thanks for any advice
So SBT will not cover the RV gear issue because it's bottom end?
Sent first motor back because of a piston, got second motor with a bad piston. Sent that back
and now I have this one from them. 2X the motor went back to them and now
they won't cover it?
Almost hitting 1 year
and it's been in the water running at the most
2 hours all together (15 min. - 20 min on an off).
Rest of the time in the shop or my garage
with one problem after another, after another.
By the way Rampage, Thank you for everything.
In and out of the shop. I think you and I are the
only ones who know the amount of time and $
spent trying to get this ski on the water.
:banghead:
They always say to do bottom end instead of only top end on 15 yr ski
