The engine was mis-firing when i returned to the docks. It did not backfire though
This is my TODO list
1, Soleniod Relay (ordered)
2, Clean/dry/grease elec connections (purchased grease last night)
3, Wear ring
4, Trim plug wires 1/4".
5, Replace Coil screw with a stainless steel bolt & nut.
6, New seal for rear box.
7, Buy a spark checker & test for spark in front cylinder
8, New Plugs (already purchased)
9, Check Compression
10, Put lines on engine bolts (check for movement).
Where is the MPEM located?
I'm not sure if the oil splash is from the cylinders. I going to give everything a good whip down and see if it returns.
