Hello you All,
Finally I had the time to write the result.
Seadoo dealer cracked the pump housing while trying to remove the wear ring
So they ordered a new housing that fit on 98 challenger.
Now the housing arrived bearing assembled but the impeller stak trek 17-22. Not fitting the housing, touching the impeller seat and not moving so they told they have to order a new stock impeller.
After few hours they called back saying the pump ready we found a solution to replace the thrust bearing with thicker one and now they used my impeller again.
Picked up the pump and installed and changed the carbon seal and seats and went for a test ride.
The boat take lil bit to plan but once started it run ok but yet I still hear the metallic noise from the pump? Any thoughts???
The top speed was about 50-55km on the speedometer. Is that normal?
