I’m not able to provide much help, except to say I see a lot of threads where people chase there tails for a long time to end up it being a fuel related issue. So when i hear theirs good compression and good spark I usually advise to go through the fuel system, check it for leaks, follow Mikidymac’s carb rebuild thread, make sure the circuits from the pilot jets to carb throat are cleaned well, new needle and seat, check them for leaks, test after all back together. How long did this one sit without running? Was it hydro locked with oil? Did you take plugs out and clear it if it was, try new plugs after that. I wish you the best of luck figuring it out, this is one I’m looking forward to following.
