I purchased three Wear Rings part number 267000372 for my 2013 and 2014 rxp-x 260 pumps and my spare pump out of a 2013 GTR 215 with part number Impeller Housing 267000540 new number 271002018.
I have changed wear rings before using the freezer method and had no issues removing and installing new rings.
I am having hole shot cavitation issues with one ski, so I decided to try an OEM wear ring, just to make sure. Freezer method work fine for removal of old ring, but the new ring will not start into the pump housing and it is visibly bigger (OD) than the old one (aftermarket). Not much maybe 1mm.
My question is are the OEM wear rings harder to install than the aftermarket and at what point do I worry about breaking the new wear ring trying to install it. Or is there a special method for the OEM wear rings?
Thanks,
Thanks,
