Matt12995
The rear of the ski took on a lot of water and the rear area that has a fuse also took on water. I did not realize this for a long time. Once I found this out I series everything out and the ski ran fine on the water hose. Took it to the lake got up to around 45 display showed 12v failing or failure then died. Got it back in and discovered the 15 amp fuse in the rear was blown. Replaced it then fired it up and only ran about 5 seconds. Any idea where to start. I did clean off the terminals and reattach the red wire that is loose in the pic. Thanks.
