Congrats on such a nice craft.
I have a 2005 manual (found in premium section), and the procedure should be pretty much the same. It contains all maintenance procedures.
Engine:
Replace Oil
Inspect Support and rubber mount
Inspect Seals and fasteners
Inspect Exhaust system fasteners
Cooling System:
Inspect Hose and fasteners
Inspect collant
Fuel System:
Inspect Engine management system sensors
Inspect Fuel lines, connection
Inspect Fuel Tank Straps
Air Intake System:
Inspect Throttle Body
Inspect Air Intake Silencer fit/tightness
Electrical System:
Inspect Electrical connections and fastening
Inspect Digitally Encoded Security System
Inspect Monitoring Beeper
Inspect Battery and Fasteners
Steering System:
Inspect, Adjust and Lubricate Steering Cable
Propulsion System:
Inspect, Adjust and Lubricate Shifter system/cable
Inspect and Adjust Variable Trim System (if so equippe)
Inspect Ride Plate including coolant leak
Inspect Drive shaft/hull sealing system
Hull/Body:
Inspect Bailer pick-ups, check for obstructions
Inspect Hull
Inspect Ski post and fasteners
