SeadooDude
-What does a 1 second warning beep mean-
I have a 95 GTS with a 587 motor. The safety lanyard switch is only a switch and this ski does not have the security key feature.
I was idling my ski in a circle for about 5 mins then the ski’s warning buzzer beeped 5 times then shut down the ski. This happened a couple of months ago and I have not been able to start it since.
Now every time I push the starter switch a buzzer will sound for 1 second. During this 1 second my fuel gage powers up, but the starter does not get power and the engine does not turn over. After 1 second the buzzer goes off and the power to the fuel gage cuts out.
I checked the battery and it is fully charged.
I checked the Thermo switch for continuity and it is as is should be, a open circuit at room temperature. To double check that circuit I tried 3 things.
1. Disconnected the temp sensor wire from the sensor. The buzzer still sounds for 1 second.
2. Disconnected the temp sensor wire from the electronics module. The buzzer still sounds for 1 second.
3. I grounded out the sensor wire. That changed the length of the beep from 1 second to 2 seconds.
So I need to know what a 1 second warning beep means. I am guessing a 2 second one means that the thermoswitch is overheated and closed.
