pwgsx
Finally after check engine lights and temp issues I got everything fixed for the most part. Now for the last issue that is not resolved that has been happening from day one........Both engines- 155 N/A's start with no problems, both idle at the same rpms in and out of the water, I have adjusted the throttle cables and reset the tps with the candoo and they are almost identical. However if I push both throttles evenly to say to a target of 6000 rpm's, one engine revs to 6000 rpm's without hesitation and the other slowly increases rpm's when it suddenly takes off and stops around 5500rps. No matter where I keep the throttles WOT, halfway or 3000 rps, one engine is always 500 rpms less. Out of the water it is the same, when I start the engines to blast water out after riding, one engine rev's right away, the other putters for a second and then takes off. Since I have 2 engines, I was going to swap the coil packs and see if the symptoms go to the other engine, if not I was going to swap the fuel injectors. Other than that, I will be out of ideas. Help
