I had the boat on the trailer cleaning it and noticed that the main storage compartment in the middle of the hull is not draining. Does anyone have some sort of drain diagram or can someone help me by explaining where the water should go from here? There’s at least a 1in drain hole in the rear of this compartment and I shoved a high pressure hose into this hole (trying to free any debris) but got very minimal discharge. Basically the water from the hose just flowed back into the main compartment instead of out the back of the boat. I had the trailer pointed uphill too so any kind of gravity system should’ve drained. Is the bilge in charge of draining this compartment or is it gravity fed to somewhere else? If operating correctly, where would the bilge discharge? After removing the plastic insert below the bench seat and looking at the gas tank I see standing water there too.
When I manually use the bilge switch, should I hear that sucker run? Because when I use that switch I don’t noticeably hear anything run. I only hear the bilge when listening inside the entire compartment and it’s very, very faint.
Any insight would be greatly appreciated.
-Tom
-Tom
