08 RXP 215 bogs out when playing hard
INNOMOB
Hey Guys
So last season I did a few upgrades , riva intake , riva rear exit exhaust, Opas delete kit, pump wedge,intake grate,blow off valve , and solas impeller ..
After doing those mods I have had a constant issue when playing real hard circling and jumping around , it tends to die out and come back . Any ideas of what this could be ???
P/s/ By die out I mean bogs down and then comes back on hard again .
What's causing this is the TOPS sensor. It's a mercury switch that tries to sense when your ski is tipping over. It's giving a "false" reading when you change direction too fast or too extreme.
Hey Guys
The weird thing is , that this has never happened befor I did all the mods . But I can check it out and see what happens because im pretty savy when it comes to this kind of stuff seeing as im a car audio guy . Is there any way to take that mercury switch out or trick it anyway ?? Where is it located ?
ya but it never did this befor I did all the mods . Can i remove this mercury switch to try it out ? Or can i trick the sensor ? I know the are usually activated by mercury flowing to the end of the sensor and sending either ground or 12volts to the switch side of the switch . Any ideas how to figure this out ?
