So my auto bilge is not working, the bilge dash switch does work and pump turns on. I found the 3 amp auto fuse, it was blown, but replacing it, the auto still doesn't work. With the main battery switch off, when I remove and insert the fuse I see a small spark, like circuit completed, and it is the brown wires, so I am pretty sure it is the right fuse. I have disconnected the bilge electrical connector, taped on the auto switch, but no luck. These appear to be the Johnson Ultima switches, I found the switch for 35.00 on eBay, but maybe it is better to but a bigger pump/switch combo in? Any one mess with this? and if so, what did you end up doing? I do want the AUTO to work.
TIA Ned
TIA Ned
