05 gtx limited scic code p0112 how to fix
Paulneedshelp
I have a p0112 code and can not find any fixes on internet or what to even change I have 2 of same skis so I was robbing parts to check and still same problem code changes ecm and. Still happens code says it’s a ground but how can someone explain or send me in the right direction to fix it
you’ll need to do some research, but there is a way to use a multimeter and pull fuses one at a time while checking for a change in ground connection. Some as on a car.
