Just purchased a clean 2004 Utopia 185 w/Optimax 200 D.I. with 50hrs on engine (scanned/confirmed). Had service shop check over and service before putting in water and everything checked out great. My issue is I don't know if I have a propulsion issue or I just bought the wrong boat for my intentions. First boat by the way. The boat jumps out of the hole quickly planes out just as fast with full throttle, but at mid throttle it loses plane and feels like it is pushing through the water losing speed unless you floor it again to get back on plane. My intention was to have a boat my wife and I use to cruise around and relax on the weekends, not adrenaline runs if you will. 20-25mph would be our cruise spot most likely. Also, while trying to cruise at 20-25mph the exhaust fumes are somewhat overwhelming. I wonder if this is also due to cavitation as the engine is at higher rpms than should be at these speeds while not pushing the boat fast enough to outrun exhaust/fumes.
So, I wonder if there is a propulsion issue that once corrected we will be able to cruise comfortably at lower speeds or if by design these boats are meant to run wide open, characteristically not meant for mid throttle cruising and I should look to maybe sell and find another option.
Have also considered the previous owner could have changed impeller for more top end performance, sacrificing the low end performance.
Impeller looks good, clearence to wear ring and guard vanes seem fine. Doubt the pump has ever had any major work done...no tool marks anyway.
Thoughts?
Thanks!
J.
Thoughts?
Thanks!
J.
