2500hd
I'm having an issue with an 2003 GTX 4tec Vans edition where the IAC valve actuates constantly.  Previous owner stated that the battery would drain while sitting, so he would disconnect the battery after driving.  I found the the IAC will "click" or actuate about every 15-20 seconds when the Dess key is removed.  I was able to ride for the 1st time this weekend and it ran fine the first day, however the 2nd day the ski started shutting of.  Sometimes showing "Maint" or "Check Engine" on display.  I could here this same valve actuating alot while trying to restart.
I pulled connections on the MPEM and they looked clean and were tight. I pulled ground straps and cleaned. I just found the "Sticky" with the codes so I will try this tonight to see if any are stored..
Any suggestions on what else I should check?
