aaajaws
Bought a used 2003 GTI LE RFI 215 hours. was told he swapped alot of parts out to get running in the end he says he did but it sucked water in cylinders because he had a gasket on backwards . Anyway my problem now
Wont start sputtered couple times but no start .......... not getting fuel ??
No reply is to simple to try, yes I put 3 gallons of gas in it and it has plenty of oil
1) Good solid newer battery + Keep her on a 2amp charger when working on it as well
2) Good Spark, New plugs , gapped .o22in, new boot ends , I can see a good blue spark when when both plugs are out and grounded
3) Compression : both plugs out I have 125 psi on both cylinders
Can crank and crank but never smell fuel on the plugs ......?
4) Fuel so far I can hear the pump kick in for 2 secs every time I put the DESS on , on the fuel line left side ( I will call it a schrader valve) green cap I can depress with a screw driver and gas does shoot out .
4a) it does if I leave the key in 4 beeps ( which i read is normal) but the dash clears and then reboots ???
I did shoot some starter fluid in #1 cyl a couple times with no luck.
That's it so far , nearest service center is 1 1/2 hours away beside the fact that I love figuring it out ( or with others help ) and hate paying "stealer" rates.
Help is all I can say, I have a volt meter and know how to use it, I would much rather buy a new tool to help diag then pay the dealer.
Any and all help truly appreciated Not afraid to make a donation to your favorite charity ( beer money ) if we can figure it out. PS in the way North near Canada so freezing temps not far away
Thanks
Jaws
Thanks
Jaws
