02 Xp Won't Start
CHASE
I Have A Sea Doo Xp 2000. I Have Spark, Fuel To The Fuel Filter, But No Fuel To The Carbs. Any Suggestions?? I Have Sparyed Starter Fluid In The Carbs And All It Does Is Blow A Cloud Of Smoke Out The Exhaust. Is There A Fuel Pump On This Model Ski?
Welcome to the seadoo forum CHASE. I wouldn't use starting fluid on the seadoo. Use the oil you use to inject the engine and a little gas to make up pre mix. There is no lubrication in starting at all. It sounds like you need to remove the carburetors and clean them. If you're careful and don't tear or damage the diaphragms you won't need to buy a rebuild kit. Pay attention to the internal filters too. You model does have an accelerator pump. Do you have a seadoo shop manual? If not here’s an idea for you. You could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Let me know how you make out.
Karl
