Uponone636
How's it going, I have a 2002 seadoo xp 951 an recently been having a problem with it losing power and not turning it's normal 7000 rpm.. It will run fine id turn it off or get bucked off the side like a rag doll, get back on put key in and it feels like it's not running to it's full potential nd only turning about 6500 rpm .. Only when I pull lanyard out nd back in will it run right but if I leave it in nd only use start/stop switch it still doesn't run right .. I don't see a carb prob because of it running right most of time, recently cleaned rave valves nd has good compression both cylinders.. Is this an electrical problem or something that's common with these machines ?? Any help would b appreciated stumped right now...thanks
