02 RXDI power cutting out?
Do you have 87psi I believe from the air compressor?..a good idea is to connect your fuel pressure gauge outside the hull, so you can see if you are getting correct combined pressure?
Yes,,,connect the pressure gauge, but have outside, so you can see it,,,then you will know under load if it up to specs,,,107 I think
