Mwhitlock1984
Hey Guys Have a 02 GTX DI with 160hrs thats not starting all the sudden. This thing ran great 1st time out. Next week lost all power when putting key on lanyard, no display, no beep, nothing. Had 12.6 at battery and all fuses good on board and at rear electrical box. Found main AMP Connector 3 on board was little wet inside, cleaned up and reconnected and everything started and ran great for 6 hours all day. Next week ran for 4 hours and then it wouldn't start. Motor will turn over and crank but will not start. I hear fuel pump kick on when I install key and display works. I checked all fuses and have same 12.6volts. I pulled plugs and see they look wet with some fuel on them. I did notice display seems to go out when cranking but it comes back and sometimes will need to reinstall lanyard. It will still crank though. I was thinking maybe no spark or ground issue or even something on board. I do have continuity on ground from battery to both solenoids in rear electric box, and to engine. Also know I do have charging issue but wouldn't think that would cause no start. I did find ground pin on rectifier was green and corroded but had 12.6volts on both sides when connected. I am not seeing any error messages on display either. What do you guys think the issue could be and where should go from here on figuring out the problem?
