Eavedesian
Good afternoon all. Hopefully someone can clarify some information for me and tell me if I have an understanding of the pump situation. I'm dealing with a pump housing from an 03 GTX di that I cant use in my 02 GTX DI because someone cut the lip off where the neoprene seal goes. Yes the previous tech cut it off so, if used, it would never seal to the plate on the hull.
From what I gather there are 2 shafts that can possibly be used in a 155 housing. 1 for a thicker thrust bearing and 1 for a thinner bearing. The shaft accomodating for the thinner bearing is used in a bronze pump and the thicker shaft where the thrust bearing shoulder and bearing is used in the all plastic housings?
Are there different impeller shaft lengths in this housing or just the thrust bearing shoulder thickness on the shaft?
The washers are the same thickness and diameter?
Finally, what is the difference between these 2 impellers? Both came out of 155 pumps 1 from plastic 1 from bronze. It looks like the middle of the impeller are machined differently by the threads.
