Has anyone ever run into issues with their 951 advancing timing? I have a GTX that I’ve checked compression on, replaced fuel lines, rebuilt carbs, replaced wear ring, etc on. I ran through all that stuff. I replaced the throttle cable and TPS sensor thinking it was an issue with that, but after recently putting a new one from SBT in I’m finding that it’s not the case. It definitely felt electric when it happened. The ski would run at 6500ish rpm then suddenly cut down to 4000rpm, not bog. Now it doesn’t even get past 4200. I suspect it’s a timing advancing issue. Does anyone have any advice for me? Thanks
