01greenchallenger
Long story short I had the carburetors rebuilt after having problems with the boat flooding out a few months ago and to my luck after putting everything back the stator went bad and 3 flywheel magnets came loose. I replaced the stator and put a new fly wheel and the boat started pretty easily. After taking out on the water the mechanic adjusted the carbs out on the water and it ran pretty good. It revéd to 5k and was kitting about mid thirtys. The water was a bit choppy so I fingered it was normal. When I went out again the next day I could not get it past 10 mph at 4K and it started to struggle and turn off. I managed to get it back to the marina and put it on the trailer again. Called the mechanic and he said it could be the fuel pump. I rebuilt the pump with an mercury quicksilver kit and replaced all the fuel lines for peace of mind. But I still can’t get it to run right. I’ve check the Manual and can find the settings for the mixture. At this point I’m thinking that the mixture is wrong but I can’t find how to rest the mixture so that I can check that off as a probable cause. I’ve also drained the tank twice and refilled it. By any chance does anybody know what the settings should be in the mixture screws?
