Typically caused by engine out of alignment. Couple that with no grease and bumper and they are pretty sure to strip out.Can this happend if you suck in some debris or what can cause this? ...no grease?
It’s hard to tell with all the grease but I’m trying to get an idea of what the splines look like in the PTO. Impeller tool held tight and was able to hold the wheel while I forced the small bolts loose. Would I be able to get away with keeping this PTO or would I be safer replacing it to prevent another shaft from stripping? Thank you guysI didn't realize you had a 951 engine, You got lucky and the PTO with the splines just unbolts. No need to lock the crankshaft or mess with the engine. Just unbolt the part with the splines and you are good.
Perfect just wanted to double checkOnce you get it out I would clean it good with solvent and really inspect it thoroughly.
I would find it hard to believe the driveshaft would be that damaged and the PTO is fine.
No it sure isn’t even. It’s really just on one side of the carbon seal! When I pulled the pump after this happened there’s was literally a half inch or even of movement in the impeller shaft. You could grab the impeller and just slide it in and out. I had to bang the thing with a mallet until it blew apart and out came tons of little rusted pieces of disengaged bearings. So maybe all this movement caused it to sit uneven? My engine is rock solid against the hull when I pull on it. Maybe I’ll check the alignment. Thanks !My guess is that the pump was not secured evenly on the hull,,which could explain the uneven wear on the pump seal, , and consequently uneven wear on the spline,,,I would realign the motor, put in new pto,,,if the splines are worn,,,new drive shaft...obvious...and ,,new pump seal.,,,is the wear on the carbon ring even?..hard to tell from the pics,,,that would also indicate incorrect pump motor alignment.
Previous owner of my boat could't get the engine align , turned out that the engine mounts was worn [emoji848]Yes engines can and are out of alignment that have never been removed. I would say more are out of alignment than ones that are correct.
My theory is that either the factory wasn’t very careful from the start or the hulls flex, settle and warp over 20 years time and the pump and engine get out of alignment.
I would definitely check it in your case.
Awesome thanks. Do you recommend I get the fiber glass fixed in that tunnel? You can see the damage in the original pictures I posted. I’m worried it was cause some sort of uneven pressure in the jet or something. I just want eliminate as many problems I can.Yes, one on each end.
To add to this.No the motor doesn't have to come out.
I get the engine to TDC on the rear cylinder with a straw down the sparkplug hole then go clockwise from that until the straw drops about 3/4" then feed rope down the sparkplug hole to lock the piston. When you turn the PTO counterclockwise it should jam the rope between the piston and cylinder head. Then use a chain wrench to unscrew the PTO.
This picture is telling me a few things.Yeah upon further inspection the edge of every spline is worn down. I don’t even know where to begin on repairing the PTO. I agree with you it’s probably screwed up as well. I guess this shaft could be my problem then?View attachment 53951
Besides the wear, its the two steps of wear. Its as if your driveshaft moved forward. And started wearing on a different spot. I've seen motors replaced and this happened because the motor was too far forward. And the impeller splines striped because it was so far out.
Check the motor mounts.
Make sure you had the rubber driveshaft bumpers.
A quick check is to reinstall everything as you found it without the carbon seal and see if you can move the driveshaft in and out.
I'm willing to bet your engine needs to move back and that there was no bump stop between the driveshaft and pto.
