SurfBeat
It's Tuesday morning, and with some free time on my hands, I logged onto the civil and courteous SDF, (unlike the PWC Forum where some members, when faced with opposing views can become rude and obnoxious), I thought I would share some information that I recently discovered that hopefully will be helpful and not be perceived as tossing fuel to the fire to get emotions boiling.
Last night I read an article entitled "Set Us Strait" written by Dan Arcy (Shell Lubricants’ OEM technical manager) in ROTELLA (Shell Oil) Monthly News Letter for the month of October 2010.
The article focused on the issue of whether mixing synthetic oil and mineral oil would harm an engine.
According to Arcy, "it will not."
Arcy pointed out that "it is an all too common misconception, and one with no scientific data to support it."
Arcy supported his position by pointing out that when switching from a mineral oil to a synthetic, or vice versa, "you will potentially leave a small amount of residual oil in the engine"
In Arcy's opinion, "[T]hat's perfectly okay because synthetic oil and mineral-based motor oil are compatible with each other. . . [thus] there is no problem with switching back and forth. And to be clear, there is no problem with switching back and forth between synthetic and mineral based oils."
Arcy then supported his position be pointing out that: "There was a time, years ago, when switching between synthetic oils and mineral oils was not recommended if you had used one product or the other for a long period of time. Some operators experienced problems with seal leakage and high oil consumption but changes in additive chemistry and seal material have taken care of those issues."
According to Arcy, "one reason to change oils from mineral to synthetic is improved start-ability."
The bottom line of the authors article is that "there is no need to be concerned about compatibility of synthetic, mineral or semi-synthetic engine oil," conditioned that "you're always using a quality product."
Albeit the article focused on automotive oil, in consideration that the issue focuses on oil being a lubricant and auto oil and PWC's/snow-mobiles/motorcycles oil come from the same place, IMO, Arcy's position is on point for us.
Let the fireworks begin.
