I have done a few of these before and need expert help. Stock 720 and 159 degree wheel. My timing marks are correct and dial indacator says TDC. With my damaged OEM valve everything lines up correctly on one side and if I flip it over it is way off. When I install my new WSM one it is off about half a tooth and it does not change if you flip it over so I need to know if this is a problem being off this much?
If the error is ok is it better to be advanced or retarded?
BTW: I called WSM and the tech was a complete jerk and told me I was wrong there was no way the valve could be different when flipped and the OEM one must be magic bucaust there's was correct and had to be the same no matter what side was up.
