robman66
Well I'm almost done the oil bypass procedure. I figured most of it out. I'm hoping someone can just clarify which two lines get plugged. I can't seem to figure out which one is the line to the crankcase that gets the brass plug installed.
Take a look at the pictures attached and please let me know.
I've got more than 5 pictures, so there will be a couple posts. Thanks.
I drained and removed the oil resevoir bottle, to give myself more access to everything. It is much tighter in there than you would think. An 8mm socket is used to remove the bottle. There are 3 bolts to remove.
The throttle linkage was very easy to remove. I just used a flat head screwdriver and popped it off. See picture "throttle linkage". The green arrow points to the throttle linkage. The blue arrow points to one of the oil pump bolts that needs to be removed.
It is necessary to loosen the fuel pump. Not only to be able to get good access to the rear oil pump bolt, but you won't be able to slide the gear shaft out with the fuel pump in place. I've read other instructions that say there are 3 bolts to remove for the fuel pump. I only found two. See picture "fuel pump bolts", I used a long allen key to reach them (I don't recall which size), and used a pair of vice-grips on the allen key to break them loose. See picture "loosen fuel pump", I completely removed the bolt on the right (blue line), and only loosened up the bolt on the left. The red arrow shows the gap created by loosening the fuel pump.
Just note, the rear oil pump bolt is a pain in the a$$ to get to. See picture "bolts". The red arrow indicates the front bolt. The green arrow points to the the location of the rear bolt. Once you break it loose, I just turned an extended socket by hand to get it completely out. You need an 8mm socket.
Continued in next post.
