Hi,
I know i'll be resurrecting an old thread (seems to be a common topic though) by doing this, and if someone feels this should be its own separate thread then that's fine, but I think it has several similarities that directly apply to my situation as well.
I have a 96 SeaDoo SPI that has always ran great. (I have owned it for 9 years) Other than the occasional bad gas left in the tank over the winter, but once i get it started, it works great the rest of the season.
The first time I tried to start it for this season was a few days ago. I forgot to use fuel stabilizer over the winter and when I couldn't get it started, I figured that was the problem, like it has been before. Long story short, I ended up using some starter fluid and pouring some gas into the air intake to get it started, and once I did that a few times it would start up quite nicely on its own. The first time it started that night (last night) it was VERY smoky. which didn't really surprise me. Myself, and the guy that was helping me, agreed that we thought it had accumulated excess oil somehow over the winter (which I think I managed to confirm is at least sometimes a problem via other posts on this forum) and perhaps that was partially the problem with hard starting, and the gas wasn't so bad after all.
Today, I took it out to the lake to make sure it was running good and to get a majority of the old fuel burned out so i can get fresh gas in it as well as burn out any gunk that had accumulated over the winter. (turned out the gas wasn't bad, but it's definitely not fresh). Everything went great today, cranked very quickly, ran good, idled good, everything. no sounds out of the ordinary or vibrations or anything unexpected. About 30 minutes or so into the ride, I thought to check the amount of smoke coming out. I didn't notice any at all! So i second guessed myself and thought, well maybe it's not noticeable when i'm in the water and is only noticeable on the trailer. so i kept riding. I was also checking the temperature of the cooling water spray (near ski fitting) to see if it was abnormally hot, and it was fine. (I have felt it hotter in previous years) It actually cooled off the longer I rode. I rode about 1 hour total and a majority was at full throttle. no abnormal symptoms at all. When I got it on the trailer and cranked it again, there was no smoke at all! A huge change from last night.
I heard from a coworker earlier this week that the oil pumps are known for failing on jet skis and i should consider bypassing it and going pre mix. so I came here and found this thread.
Tonight I did troubleshooting. I looked in the service manual and found the oil control lever and did the test they recommend as well as someone on this forum suggested. at idle, press the oil lever wide open and it should smoke heavily. I did that multiple times, and NO smoke at all! No change in engine sound. Checked the oil filter and it flowed fine, cleaned it real good and reinstalled, still no smoke. The only thing in the manual i couldn't do was bleed the oil line because i couldn't determine where the bleed screw was from the diagram (it wasn't very clear).
I know for a fact that it has been smoking in previous seasons.
So first of all, Is there anything that could be wrong here that I haven't checked yet that is or could be an easy fix? I don't feel comfortable taking the pump off and manually testing it with a drill for fear of breaking corroded bolts, seals, gaskets etc.
Next, If in fact my oil pump did fail today or sometime during the winter, and I rode for approximately 1 hour at full throttle with no oil flow, how did the engine not lock up and how are there no symptoms of anything wrong? The service manual makes it sound like it's the end of the world even if you just change the oil filter and don't bleed the lines before running the engine.
I'm not at all opposed to going pre mix, but I don't feel comfortable trying to remove the oil pump. If I do go pre mix, how long is it going to take that oil to make its way into the engine for the first time?
I really appreciate any help on this. I'm hoping to ride some more this week and hope to get good use of the jet ski this season.
