Adding too speed is NOT what an intake grate will do. It forces more water into the pump tunnel to keep the impeller loaded at all times, thus causing more drag. If you ride in choppy conditions you may see an increase in top end due to the grate keeping the fed with water. In smooth glass like water the grate will slow you down unless you make more power to compensate for the drag. I think the biggest benefit I saw from my Riva Top Loader was improved fuel economy in rough water. Kept the ski from constantly loading and unloading the SC and RPMs stayed steady. That also reduces the wear on the SC washers.
So is it worth it? To me it was due to the rough water conditions I rode in regularly. Is it worth it to you? Only you can determine that. If you're looking to just increase top end I'd look else where.
