The 787 motors all use the 1.5 seats I believe. This site lists the 1.5 seat as well:
http://www.seadoosource.com/carbreference.html
If you want to be certain, the factory service manual should have the correct info as well, www (dot) seadoomanuals (dot) com has a nice library of factory manuals, grab one if you waven't already, there's tons of important info in the manuals.
The seat/needle set you would want could be either of these two types, 1 each/carb, I use the normal type which has worked flawlessly for decades, inspect the seat internally(with magnifier lens) and polish the surface with lapping compound if you see burrs on the seat (sometimes low quality aftermarket parts finish is poor) or reuse the original brass seats.
786-35018-1.5 (high alcohol resistance tip)
786-35015-1.5 (normal tip)
After removing the internal filters for cleaning then you should be able to blow them clean with a few gentle shots of air, or you can spray through them with acetone based carburetor cleaner to reverse flush them if you like.
The carburetor to manifold gaskets might rip or tear when you remove the carbs, you might want to have a spare set on hand. I often am guilty of reusing them unless I have a set handy or the originals are too beat up. A little heavy grease can hold them in place while fitting the carbs.
