Guy on the water
It looks like there might be 2 different stock numbers for the DCPR8E plug. I purchased 6 plugs today for my '03 GTX supercharged from an auto parts store. They are stock# 4179. I pulled the coil off the plug and peered down and noticed the tip is much more narrow than the plugs I bought. I figured I could unscrew the tip of the plugs I bought and then have a more narrow tip, but the tip is solid and does not unscrew. In fact, the spark plug box shows a picture of a thin tip with an "X" through it and shows a thick tip with a circle around it.
Every thread I searched here just mentioned DCPR8E, but it looks like that might not be enough info. to get the correct plug. I've done some more googling just now, and found this:
"DCPR8E stock #4339 is the one you need
DCPR8E stock#4179 has the solid non removable top"
from here: http://www.sea-doo.net/board/thread.asp?threadid=76302
This info is not on this site as I searched both '4339' and '4179'. This isn't news to most of you here, but helpfully it will help another noob down the road.
