LikeabossTM
What is the consensus on anti-tamper plugs and adjustment screws for a carb rebuild? I'm happy to leave them in place and just clean out and rebuild everything else, but was a little bit concerned that if I end up with some crud in those passages that I won't know it until it's too late and I lean out the engine.
Do folks on here typically drill out the plugs and do a full cleaning after removing the adjustment screws, or just leave the plugs in place and clean everything else as best you can without removing the ls/hs adjusters?
2004 GTI 720
2004 GTI 720
