sledman1
Calling all jet pump experts. I have a 98 GTX Limited (951cc). When I purchased it and used it for the first time it had a chatter coming from the jet pump only when the jetski was in the water and at idle. No chatter when out of the water or as soon as I give it some gas in the water. I pulled the pump and replaced all the bearings, the driveshaft and the wear ring. The original wear ring was brass and it was scored up. The impeller was dinged up a bit but decided that it was good enough to use and just cleaned it up with a file.
The ski still has the same chatter as before after the pump rebuild. I pulled the nozzle off and inspected the new plastic wear ring and it is scored up. The ski cavitates when you first start off and that has gotten worst with time. The impeller edges facing the front of the ski are now in bad shape. I have not sucked up any rocks since the rebuild, just weeds. I am guessing the cavitations have damaged the thin leading edges of the impeller. Any ideas as to what I missed or did wrong? Thanks so much for your help.
