Shane0524
I have a 96 gtx that appears to be leaking oil from around the grommet on TOP of the tank. The leak appears to be coming from around the sender unit for oil level readings. The sender is very loosely fitted in the tank. Is that how it is supposed to be or should it be quite tight. Also where is the grommet on the bottom that everyone talks about leaking too?
thanks for any input!
http://youtu.be/uOsm_vE_VJo
