Have a 96 gtx with a rebuilt engine. Ski ran great for about 3 or 4 minutes then started running rough. Was able to start it and keep it running if I sprayed starting fluid down carb throat and pulled choke then slowly let off it. It would only do about 10 mph. At one point, I pulled the plugs and one of them looked wet, as in wet with water - kind of rusty looking - and it was a brand new plug. I rebuilt the carbs, pop-off test and compression tests passed, had it out and got the same result. It ran great then started running rough again. I'm thinking that the issue could be with the fuel. The gas lines have already been changed and seeing as how it ran great twice, I'm pretty sure it's not a clogged fuel selector issue. Thoughts?
