Doug Overkill
Working on my 1997 Seadoo Challenger 1800 with twin 787's. Some may have seen my other recent post about 2-stroke oil leaking past the crankshaft seal and hydro-locking the Mag cylinder on the port motor. After a bunch of overthinking it, I decided to tear apart a good working motor to solve that problem. I hoped things would look good and adding Yamabond4 to the crank seals would solve the issue. If only things went as smoothly as that...
First thing I noticed is that the counterbalance shaft is supposed to have a top fill plug and a bottom drain plug for adding the 1oz of SAE30 to the gear. My cases have the top fill port but the spot that is supposed to be a drain plug has no hole in it. Picture from manual shows where it should be. the pic from my case doesn't have this drain hole. WTF? The Starboard 787 motor does have this drain plug...
The next thing I noticed is the Mag side counterweight area has a lot (couple ounces) of what looks like 2-stroke oil in it. As best as i can tell this area should not have any oil/lubricant in it. The seals SHOULD keep the oil out of this area. Am I missing something or is there supposed to be oil here? I'm wondering now if the issue with 2-stroke getting into the MAG crank journal is actually coming from the rotary valve via this counterweight journal??? Anyone have any thoughts? It certainly looks like the seals on the counterbalance are bad and should be replaced.
