I've been having issues starting the boat. It will crank but not start. Fuel pressure about 37psi at the valve.
When cranking, it just sounds dry like there is no fuel. Spark has been checked and is good.
In the process of checking components we discovered something odd. If cranking a few times, then disconnecting the positive on the VST tank to disable the pump, it will start up after 2-3 cranks. It will run for about 5-10 seconds, until it burns the leftover fuel.
As soon as the VST positive gets reconnected, the sound while cranking changes immediately, sounds like a dry crank (constant, no bucking) and it will not start.
The only thing I can think of is the fuel/air ratio is messed up.
Thoughts?
