Talbachi
So I decided to check the piston squish to the head.., based on what could get at I'm measuring about .078-.093 for my squish with the gasket on, which seems way to much. It is entirely possible that I wasn't fully against cylinder wall and would then have a reading of .0625 to .078. I need to really buy some calipers... I will be checking it metal to metal to verify. If indeed it is that reading what are my options? I assume i would need a thinner base gasket? where do you recommend finding a .4mm gasket? I'm assuming I have .5mm gasket in there from SBT.
