2-Smoke
I have an interesting but irritating issue with my 1996 Sea Doo XP. The ski starts and idles perfectly both in the water and out of the water, but as soon as you leave the boat ramp, it will hit 3800 rpm and feels like its bouncing off rev limiter. The RPM is always the same. It will however rev out on the trailer. I have been chasing this problem for a few weeks now and I haven't made much headway with it despite changing and testing many of the parts that commonly fail.
The XP had both carbs professionally rebuilt at the end of last season with genuine Mikuni parts from OSD, and it was running perfectly. Now it is having this same issue every time it is taken out on the water this season. All grey fuel lines were replaced already when I bought it.
So far tests and checks I have completed include:
-replaced the fuel selector with a brand new OEM unit
-bypassed fuel filter
-tested rectifier (idle at 13V and 5500RPM at 13.7V)
-tested to see if any A/C voltage is reaching the battery
-Ohm tested ignition coil
-changed sparkplugs
-Ohm tested stator and wires going to rectifier
-trimmed plug leads back 1/4 inch
I did notice when you unplug the battery on the water and put it back on, the ski will do one good pull up to about 6000 rpm and then the issue returns and it right back to 3800 rpm again.
Does anyone have any ideas of what might be causing this issue?
-changed sparkplugs
