michaellowery
Bought two jet skis. What a deal right? Holy cow. Just to preface i do enjoy small engine repair and i am mechanically inclined and i am stumped but also not afraid to ask for help.
00 seadoo gti 717-
Several problems
Changed fuel lines, carb rebuild, new starter, new stator( it was in a thousand pieces when i pulled the flywheel), replaced the motor with sbt motor due to oil seals leaking, got an after market mpem for now just to get it started. Plan on sending mpem to get checked soon.
Problem 1- timing on the stator. Since my old one was in pieces, no marks or anything. I read somewhere that sbt blocks just set it in the middle of the stator grooves. So i set it there to start. Won’t hit a lick. Any suggestions? I poured gas directly into the throat.
Problem 2- will not pull fuel from the tank. It has pickup tube on it. I cleaned the selector and i can suck/blow gas and air through it. I can pull gas down to the carb but it will not pull it into the carb.
Problem 3.- the oil pump will not prime. I know i can run just mixing it but it will not prime for nothing. I’ve seen the videos and mine will not work anymore. So weird. I’m gonna pull it off again and try to prime. It did work before i pulled it off of the motor.
Any ideas why the carb will not pull gas in? I know the lines are correct. Pulse goes to motor, return goes straight to the tank, in comes from the bowl up front.
00 seadoo gti 717-
Several problems
