WaarrEagle
My 2000 GTX DI will currently not start, ~225 hrs on the motor. For years it has idled a bit rough but would not die. Last year it was going into limp mode and I took it to a local mechanic. He replaced the regulator, gave it back, and the ski was still not running correctly. I took it back, he replaced another part (something cheap, ~$30, but not documented on receipt), and it ran better but even then I recall the idle was not perfect.
This season it ran okay for several weeks but recently it would die at idle. If you got on the gas it would run great, ran it up to ~6700 RPM without issue at ~55 MPH. When returning to idle it would slow to 1350, then 1250 and die. It is now at the point where it will not start at all, even with throttle. It turns over, catches quickly and runs for a brief moment, then stops and you hear the 2 puffs of air or whatever when you turn it off. I had the battery checked at the auto parts store... it tested fine. I used jumper cables to tie into a much larger boat battery thinking perhaps the voltage was dropping, but got the same result.
I am pretty tech savvy but have no tools currently for the ski. Should I be checking voltage, fuel pressure, compression, spark plugs, etc or just take it to the shop? I see lots of folks with trouble on these old DI's but would like to try a couple things before losing several weeks of summer waiting for service at the shop.
Edit: Not my video but it acts very similar to this:
The poster said the air injectors were his problem, but did not elaborate on what exactly needed replaced.
