Beep solution?
Advanced Self-Diagnostic Mode
It needs to be enabled manually. Proceed as follows :
1. Remove safety lanyard from watercraft switch.
2. Press 5 times on the watercraft start / stop button.
NOTE : 1 short beep and 1 long beep must be heard. They validate beginning of diagnostic mode.
3. Install safety lanyard on watercraft switch.
4. Press the watercraft start / stop button again.
NOTE : If everything is correct, engine will start. Otherwise, refer to the following chart.
SIGNAL
No beep Engine actually starts. Everything is correct.
1 long and • No safety lanyard has ever been
1 short beep programmed in watercraft
MPEM.
2 short beeps • MPEM can not read the digital
code of the safety lanyardcap or
the magnet is defective.
• Mixed wires at safety lanyard
switch connectors or bad
connections.
2 long beeps • Wrong safety lanyard or bad
connection of the DESS wires.
3 short beeps • Wiring harness of DESS switch
is grounded or there is a short
circuit.
