Guys
I have been around small engines and motorcycles my whole life and am new, not only to lake life, but now jetskis. I have been thru the manual and it doesnt
give me the detail I need so here I am your mercy
Situation
First day out with both of my new (to me) jetskis. Both are the same 2002 Seadoo Bombadiers GTI LE. Neither had been used in app 1.25 years
Played some with the first one and found that after a little tweaking and and cleaning and normal spark plug maintenance, I had a dead battery. I had a battery so I changed it out and all was cool.
Second one, basically the same thing, I did not have a replacement battery, so I jumped it and rode it for about 30 minutes to see if it would take a charge from the system. We brought it in to the dock and turned it off, no good response from the battery, so I re-jumped it to bring it over to the launch to run out and get a battery and do the work. It started but would not idle. After the 3rd jump I realized I had turned off the gas line. So I turned on the gas line and in my haste crossed the positive and negative and blew the fuse.
I dragged the jetski over to where I could leave it and went to get a battery and some fuses
Upon my return with the battery and fuses, I changed them both out (turned on the gas) and now with when I connect my lanyard, I get one long beep.
I did the diagnosis of the DESS and the advanced self diagnosis. Every time I plug in the lanyard I get a single long beep. When I do the self diagnosis I get 2 short beeps. According to the manual this means that the MPEM cannot read the lanyard cap, magnet is defective, or mixed wires at the switch connectors or bad connections. Given the situation, I do not see the mixed cables as being a possibility, I dont find the magnet being defective as likely
As a newbie I do not have the MPEM reader / tester and am hoping, that someone out there might be able to give me some direction
MEWING
Situation
MEWING
