So, I have a 1996 Yamaha WaveVenture 1100, and it runs fine out of the water, and in the water it idles nicely, but bogs down and stalls if I give it more than a small amount of throttle. At first, it topped out at 6 mph with people on it, and a little higher without them. It takes a while to even get to 6 mph. I have to keep the throttle constant and low, and let off when it starts to bog down, or it stalls. It starts fine if it does, but then it's a slow trip back up to 6 mph lol.I let it run for a bit, and it got a bit better, but not much.
I replaced the fuel filter and ran some sea foam through the carbs, and that helped a lot. But to start off, I need to run it half-choke till about 6-8 mph, then it's fine unless I stop for a minute.
So, what's the problem?
I did a search and didn't find anything related for this model, but similar ones led me to believe that the problem is the carbs. I don't have a manual on the ski, and it's been a long time since I've done any carb work, so I need all the info you can give. If I clean the carbs, what exactly do I need to do, and what do I need to look out for? Same question goes for rebuilding them. What do I need to rebuild? What do I need to be careful about when rebuilding them?
Where is a good place to buy parts?
I haven't had any luck locating a manual too... suggestions?
Thanks!
Thanks!
