XP electrical help
SLOW 91
I have a 98 XP, and when i bought it there was some small wire problem in the front box that has the ignition solenoid, and starter solenoid. Anyways there are 2 waterproof fuse holders and the 2 wires comming out of each have nothing attatched to them. Now i see 2 white wires that seem to have gone into the fuse and then the other wire to the fuse looks like it went to one of the posts on the ignition solenoid. Is this correct? Any help would be great.
White wire?.......
I can only see one solid white wire going to the coil itself. The coil should have a white and 2 black wires.
Trace this fuse link your talking about and see what block it goes to in your electrical box. They are numbered and maybe I can help you out further. This could also be something just sdded by someone, that isn't suppose to be there......
just went outside to double check. there are 2 white wires that come from the top of the box. One is solid white with a green stripe, and the other is solid white with a red or orange stripe.
